Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Can someone tell me why it leaves an empty space of about 10 gigabyte I would assume from 5 gigabyte in on the harddrive? All internetfiles,trashcan, swapfile and such is on a separate harddrive??
lol cuz it sucks i dunno. mine does the same i have a 80GB and it leaves a HUGE gap and then puts some chunk at the end. swap file is on other drive...
Yep, thats why I bought a third party app, O&O defrag. MS would only half defrag, or tell me to run chkdsk when I didnt need to. O&O gives you the option to do a regular defrag, or place files on the drive by name, date modified or last date accessed.
