Microsoft Patch Re-released
FrgMstr
Just Plain Mean
Staff member
If you manually downloaded critical patch MS08-051 for Office 2003 since 8/12, you need to go and get the 2nd version that was recently released. The initial version that was posted was incomplete, missing “important security and reliability updates.” If you got the patch via Windows Update or WSUS or you’re not using Office 2003, then you don’t need to worry.
The company said it had posted the correct versions to Windows Update and Office Update from the start. "This only affected the packages on the Microsoft Download Center; Microsoft Update and Office Update contained and were distributing the correct versions of the binaries and did not need to be updated."
