Microsoft: No More Pick-and-Choose Patching
Well, just because this is where most people are going to see this, I am posting it here: I have what seems to be a fix for the Windows 7 update issue. (Or at least I can repeat the results consistently.) Doing a straight up clean install of the 32 or 64 bit Windows 7 with SP1 already part of it, I was then able to instantly install the patch I downloaded back in March. After that, I checked for updates, about 1 or 2 minutes later it showed the 228 updates I had for installation, I then installed them and everything worked. It seems to only work correctly and consistently on a straight up blank, clean install and not a recovery partition or cloned image of an existing Windows installation.
Sometimes it immediately patches and sometimes it takes hours to a day. Having a SP1 integrated ISO does nothing to help, you just got lucky that particular time. Also holy thread derail Batman.
I am not talking about a SP1 integrated ISO but an actual straight up clean install with the disc already having SP1 on it. Yes, it does help and I have been able to consistently reproduce the results. If you do not like this, do not read it but I am absolutely certain it will help others. This is also no derailing since it is about updating the OS regardless.
Hate to be that guy... I just recently installed Windows 7 with SP1 integrated and I still had to leave the machine all night and into the next morning before Windows Update picked up the 233 patches it needed. Fresh install.
I agree with the poster who said it varies and you never know how long it will take.
Yes, that's what I said an install disc with SP1 already on it and you are also wrong that it might reduce the Windows 7 not downloading patches issue. It's got nothing to do with SP1 and everything to do with Microsoft's end of their patching service.
Yes, that's what I said a install disc with SP1 already on it and you are also wrong that it might reduce the Windows 7 not downloading patches issue. It's got nothing to do with SP1 and everything to do with Microsoft's end of their patching service.
Skip it, if you want to argue and claim I am wrong, that is fine, go on ahead and continue doing what you are doing. Me, I have reproducible results that have worked every single time. Install Windows 7 32 or 64 bit with SP1, install Windows6.1-KB3102810-x64 or x86 which installs immediately, run Windows update after a reboot and 2 minutes later, it shows and is ready for installing the updates. Feel free to argue it or try it for yourself, no skin off my nose.
See Manofgod, there's further confirmation that you are wrong. You have to do a large number of installations to see the big picture in that the problem is on Microsoft's patch server end and not our proven to work, read-only Windows installation discs that have patched perfectly fine since 2009. You simply lack the experience to know what your talking about so just leave it to others more qualified that are already here.
I lack the experience as an IT Pro, LOL! (If you did not get it, I am an IT Pro and although I do not know everything, when things do work, I share them with others.) Sure thing dude, enjoy doing things the way you always have, I will do things the way I have been consistently able to get them to work when I can do a clean install.
Edit: Although, it may be that I am specifically using a Dell OEM Windows 7 disks so I will do further testing and see if this works because of that or something else.
Well, that is 5 installs in a row that have worked the way I have mentioned. 3 Virtual machines, 2 real machines, HP and Dell, 32 Bit and 64 Bit. I am now trying a virtual machine with a Windows 7 Home Premium 64 bit non SP1 disk clean install and seeing what happens.
Edit: Correction, 6 in a row. If someone else would give it a try as well to see if you can replicate the success I have had, that would be appreciated.
There is a linux compatibility layer in FreeBSD. I wonder if that might work? Another option (does your brother support postscript?) is just using postscript.
Naw, I got one of the cheap ones so there's no postscript. I got it before I started looking at Linux or FreeBSD. The next print will have postscript.
ManofGod, your solution is probably valid - until the next patchday, at which point the Win7 Updater will probably break itself again. That is what you are failing to test for. See:
Search for Windows Updates takes forever? - A possible solution
Thanks for the info. However, at least for the 2 virtual machines I installed from scratch, one a month ago and one about 2 weeks ago, they both are installing any new updates almost instantly. Even the Windows 7 32 bit that we installed on computer for a customer went quickly. The last scan is taking longer but, then again, it does not have an SSD in it and I would imagine the updates will install overnight anyways.
The most consistent times I have seen the issue is with cloned images or when I used a recovery partition. Something on the local computer itself is causing the problem when communicating with the update servers but the real question is, what is it?
Edit: I have to admit that I did a whole bunch more installs today as a test in part because someone claimed I lacked the experience. :D Nature of the beast but sometimes, strange things can motivate us.
We need a [H[ard W.U.S.S. (Windows Update Soapbox Server)
Then we can just get our updates here if you can get to the soapbox!!
I recently wiped a 10 box and installed 7. I don't have the SP1 integration CD. From a clean install, Win Update was broken. I pulled the Update Updater from MS website and installed. It found SP1 and a couple other minor patches. Install failed for all other patches then SP1. Rebooted the box. Ran Check for Update and it took nearly 3 days before I was growing frustrated.. Pulled a KB patch from MS website that is supposed to help the problem. Installed the patch, ran check for update again. Finally, after a half hour, it found the rest of the patches. For the TL;DR folks, this is a broken system. So many "fixes" to get patched before I could throw the box back into production.
Someone has to make an app that switches the updates off at least so it doesn't update while I am updating something else or writing letter or any damn thing else I may be doing.
Use a version of Windows 10 besides Home. Done.
I wouldn't say another nail in MS coffin, but another nail into the desktop, as Microsoft and Intel pretty much created.
MS is cementing the future of phone-like computing everywhere.
Thing is, competition is nothing but strong there.
Amazon is getting scary huge, Google is scary huge, Apple is disgustingly profitable, and huge.
MS is entering 'cloud' computing surrounded by freaking insidious, profitable, sharp-teeth, agile giants.. Good luck this time MS.
Same, built my TV computer the other day with Win 7 ultimate x64 with SP1 and it tool all night just to load the patches. Its hit or miss with windows updates despite which updates you have. That first initial batch of updates you get from a clean install seems to always take a while.
Thread title, for once, is accurate... for certain instances.
I am complaining about the same thing as the thread title. Maybe that didn't come out right. Sorta like this mornings trip to the pool to drop the kids off.
My firewall has successfully prevented my desktop from updating windows 10 to the anniversary update. <3 sophos.
