Microsoft Natural 4000 keyboard Problem
antok86
i just got this keyboard and love it...but i have one problem....the keys die and stop functioning....then i have to unplug it and plug it back to get it to work again...i googled it and seen that some people have the same problem....anybody else have this problem???
now that i updated the keyboard using the drivers on microsofts website....everytime i press capslock num lock..it disconects and makes the sound as if i unplugged it from teh usb, and the lights go out and come back on...and i cant use caps lock...
wow... im using the keyboard without the "drivers" or intellitype installed. works great for me. maybe you should rma it, lol.
well i kinda fix it...only thing is it disconnects every so often...sucks
If it works fine in another system, then its the board's USB ports or drivers. You can try uninstalling/reinstalling the root hub.
the two problems i found are..when i press caps scroll or num lock the keyboard disconnects and makes that sound and then reconnects. As if i unplugged and plugged it back in. 2nd problem is when i type it just dies..i cant type only the media keys such as mute and volume seem to work and another instance is instead of just dying a key will get stuck and go on as if i was pressing it....
