Microsoft Laser Wireless Mouse 6000 Quirk !
MOC
Well was time to get a new wireless mouse ,so I picked up a ,
Microsoft Laser Wireless Mouse 6000 ,I install it and let the software
install > Nothing , dead..remove the software ,go through and delete
all existing reg.keys and device manager install for mouse ,and usb .
Try again ,still nothing ! do google on the subject ,and get microsoft :
http://support.microsoft.com/kb/321122/EN-US/#XSLTH4128121124120121120120
IntelliMouse: The Mouse Pointer Moves Erratically or Does Not Respond with Windows XP
Go step by step with the reg. keys delete,reinstall nothing (fed up by this time ) go too
Microsoft mouse help page ,(did every thing already ) checked all my usb ports ,everything is fine ? Finall get my old logitech wireless optical mouse back out
(200 dpi ) and every thing is fine . Next day I start to recall everything that I did ,(since
I would really like to try it's 1000 dpi ! ) So I come home from work ,and unstall the Logitech ,and start the install process all over again ! this time after unstalling all mouse
reg. keys,and human iterface devices . I by accident knock the mouse off the mouse pad
(Allsop metal optical mouse pad ) it worked .What was happening was the mouse pad being a dark slate color would not let the lazer work for some reason,maybe being to dark . Had too remove the mouse pad ,then iI tried other mouse pads that I had ,no work.
the only way I can get it to work was mousing on the desk ? It's a great mouse ,and feels
really good in the hand (best mouse I ever held bar none ) Just wanted to share that.Also
all mouse pads that I used ,that I had were dark in nature .
