Microsoft Laser Mouse 6000 C6W
Cantonious
Anyone have any experience with this mouse? Pros? Cons?
How is it for gaming? My intellimouse explorer 3.0 just died on me.. (Ok so I killed it on the wall..)
Anyway, please leave your thoughts...
I checked the 6000 and the old one you killed and I would say yeh... get a logitech mx1000
Or... I don't know if you're excited about the laser part of it but I would say even going from a Intellimouse to a (non-laser) logitech MX 518 optical mouse will do wonders. Having 8 buttons at your disposal really helps.
Also, The 518 evidently has some sort of "on the fly" sensitivity that will let you do things like turn a tank turret in BF2 faster
http://www.newegg.com/Product/Product.asp?Item=N82E16826104178
Ack, multi-button mouses suck, I am always pressing down on those extra unneeded buttons at bad moments.
$15 Logitech black optical mouse ftw.
You're blaming an awesome mouse for your clumsy fingers... does not compute.
I use the MX510. Even without the resolution adjustments, it still kicks ass. Too bad I suck so much.... :(
May I suggest using the control panel applet to disable the buttons that are tripping you up?
