- Apr 25, 2001
Microsoft has released an emergency update to their malware protection engine that most users should get automatically. What makes this so funny is the fact that what's supposed to protect your system has to be fixed to protect itself. Anyway, it could have been worse if MS called this a feature instead of a flaw. However, if you don't have auto updates turned on, it would be a good idea to go download the patch and install it manually.
According to Microsoft, the vulnerability can be triggered when the Malware Protection Engine scans a downloaded file to check for threats. In many systems this is set to happen automatically for all new files. By exploiting a memory corruption error in the malware scanning tool, the attack file would be able to execute code on the target machine with LocalSystem privileges.
