I really need your help on this one.
I was running Microsoft Office 2003 perfectly fine, until 4 days ago. I use Excel extensively, and can have up to 10 spreadsheets open at a time, so this issue is destroying my productivity.
Here's what happens. If I load up 2 worksheets and start Alt-Tabbing between them, eventually, Excel will get stuck on one of the worksheets, and not function at all. It will not read any of my mouse clicks, nor register any changes I make at all. It's not "frozen", because when you move the cell cursor, you can see it moving, AS LONG AS IT'S ON THE SCREEN. If you move the cursor off the screen, the page doesn't automatically scroll down. And no, it's not the scroll lock, because I never have it on.
The only remedy is for me to press the "New Document" button, or to force the program to end and restart it. You can see the problem getting ready to happen, because it looks like the screen will "blit", or "refresh" a few times. VERY annoying.
I uninstalled cleanly and installed Office 2007, and, although it was a bit better, it still was having the same problems.
What could be the issue? Thanks for the help.
