microsoft excel help... making budget/expense spreadsheet
kv2
So i have a little spreadsheet going where i list the place I spent my money on and how much I spent. that's about all it has.
I want it so I can put each spending into a category like "food, entertainment, rent, etc..." and somehow add up each in the category so I can see how much I spent in each category. I know I can type everything in manually but i was wondering if it was possible so whenever I typed in the entry and chose the category, it automatically adds it to the total of the category.
anyone know what i'm talking about?
thanks for any help guys! :(
Check into the SUMIF function. I believe you'll want to use it. However, you might be better off looking into using Microsoft Money or Intuit Quicken to manage your finances.
=sum(range_start:range_end)
ex
=sum(a1:a9)
Then you can also do a sheet with totals and a graph
No need to buy quicken. Just download open office
You can also hard lock formulas with $A$1 for example. PEMDAS.
The issue with your approach is that it will require a seperate column to track each category. I envisioned the original poster having a checkbook register type setup, with even transaction being entered on a new row and one column indicating the category.
In all honesty, something like Money or Quicken is designed specifically for this type of functionality and would be a better option. Both can be purchased for under $20 and provide advanced functionality, such as the ability to automatically download transactions from a bank.
Waste of money imo. You should keep your receipts and enter daily/weekly. :eek:
hm the sumif function seems pretty nice....
i'm considering using quicken but i think excel is just so straightforward... not complicating to learn. not saying quicken is but it's like a completely new program.
maybe i'll take the time to learn though...
There are tons of freeware money/wallet programs like what you just mentioned. I used to use them on my pda and know that you could use the same installer for windows install.
Once you've learned the app (they are rather simple to pick up), you can save a bunch of time and errors. For example, my biweekly paychecks include contributions to a 401k and ESPP program. Between the taxes, insurance premiums, contributions, charitable donations and employer matches, there are over 20 line items to enter. Since I'm salaried, these amounts never change and so I have MS Money set to automatically enter them. And, because I have direct deposit, I can be sure the paycheck was deposited when the transaction downloads from the bank and is reconciled to my automatically-entered transactions.
Obviously, your mileage may vary.
