Microsoft domain issue with logon scripts
Shr00m
I have 2 domains setup:
EXAMPLE1 & EXAMPLE2
On EXAMPLE2 there is a trust setup for EXAMPLE1.
When I add a machine to domain EXAMPLE1, reboot the system, then try to login to the EXAMPLE2 domain, my user that I have setup doesn't get their logon script that normally runs if the machine was originally added to the EXAMPLE2 domain only.
Is there a way to fix this?
If its XP client it can take up to 3 reboots to get the logon script unless you turn on syncronous logon
Hm, were do I turn that on at? This has been going on for months.
If it has gone on for that long a period of time then its not what I mentioned.. your issue is outside my scope of knowledge
