Microsoft Details Some W7 Issues Being Tracked
Terry Olaes
I Used to be the [H] News Guy
Ars Technica has a post that summarizes some issues affecting Windows 7 and Windows Server 2008 R2. These issues are being tracked by Microsoft in Knowledge Base articles and some even have hotfixes. If any of these are affecting you, these fixes may be just what the doctor ordered.
These bugs are not typically fixed via Windows Update, because these hotfixes should only be applied to systems that are experiencing specific problems. So if you are not severely affected by either of them, wait for the relevant service packs. Here are the four most prominent issues, listed in order of decreasing severity.
wish they fix the issue with mapped hard disks and network shares (open the maped disk thats on an share when you press back it does not show the folder any more sometimes you can press f5 but norm doe snot come back i had to go back to 2003 as it was just plane annoying when you get 4 maped disks that keep not showing ) this issue affects vista and win7 when looking at an shared disk with Mapped disks
Boot manager and NT loader; boot files get eaten by windows update. Noticed on vista/w7.
The first manifests itself when the computer crashes after it runs for some time, with the user seeing the following BSOD (the four parameters vary depending on the computer):
I wonder if my system is affected by this...
About once a week (sometimes twice in a week, sometimes not for two weeks) my system will BSOD even when it's not under load. I could be browsing the web or reading a text file in notepad or whatever, or I might just have left it at the desktop with no open applications, and when I come back it has BSODed and auto-rebooted. Like I said, only once a week at most and it's on pretty much 24/7.
It passes Prime95 tests, memtest, 3DMark loops etc. for hours without problems, and I've played games for hours on end with no crashes.
I've already tried replacing the RAM and adjusted various voltages (RAM, PCI-E, southbridge, NB, HyperTransport).
Haven't really bothered much with it in the last several months. I figured either something is faulty/dying, or it's because I run a Phenom II on an old 790FX/SB600 board...
Try reseating the CPU, that did the trick when I was crashing randomly in Win7 when benchmarks and tests returned fine
