microphone addon or super-comfy!
korkow
So I've got a kinda big head, and although im not an audiophile, I surely am a comfort-phile. Right now I have these super-comfy headphones that I can wear for 10 hours straight with zero issues. I do tons of online gaming and I need a mic for that, and I have another head set that is truly craptacular in every way possible except for the microphone, which I usually just wear around my neck for the mic only. The thing is, that makes my neck hurt pretty quickly and I REALLY need some way to get either:
a) a mic attached to my current headphones. I would prefer this if possible, I dont care how it looks.
b) a headset that is ultra-comfy, with a mic. doesn't have to have great sound quality. under $70 or so dollars.
I was considering mutilating my crap-tacular headset to get the mic and somehow graft the mic onto my current headset.
Otherwise I need some reccomendations for some seriously comfy headphones that have a mic. Most of the "high rated" but cheap-ish headsets im seeing are *on the ears*... I NEED around the ears, unless it is somehow really comfy "on the ears" (which i have yet to have seen work for me).
Thanks in advance
Just out of interest, what headphones are you currently using?
I'd just get either a desktop microphone (although that might be inconvenient if you're moving around a bit) or a more appropriate clip-on microphone which you can attach to the wire on your headphones.
