Microcenter Intel (ecc capable) cpu/mobo deal, $200+Tax
pretty good deal for a storage box using freeNAS or some other ZFS based file system. Slap in a decent amount of RAM, and a SAS controller and you'll be set.
omfg out of stock near me, I have been looking into this motherboard. FUCK/
Oh well, this board only supports unregistered / unbuffered ECC memory, which costs a shit ton more than registered ECC memory. You will be spending a shit ton on setup if you want to do ECC with a cheaper motherboard. Its frustrating, since I want to run ECC memory, but I realize that if you have a cheaper motherboard, it will only take expensive unregistered ECC, but if you buy an expensive motherboard, it will take cheaper registered ECC.
A couple months ago I found some b-stock at cdw (supermicro) 8GB unregistered ecc ram sticks for about $35 ea+ tax. I bought 6 of them, so I'm set :)
seems to me, this TS140 is a better deal
http://www.amazon.com/Lenovo-ThinkS...?ie=UTF8&qid=1408934269&sr=8-1&keywords=ts140
for $230, you get a Haswell i3, C224 chipset motherboard, 4GB of ECC RAM, Case and PSU. plus it's already assembled
Do you know the exact make and model of that motherboard?
It holds 4 drives if you take out the optical drive and a non standard PSU.
Do you mean if remove the current non-standard PSU? Or remove the one it ships with and ADD a non-standard one?
This is for the entire platform. To get reg ecc support in a current platform you need to move to E5 xeons or better.
Also, isn't it the other way around? I thought registered/fully buffered ECC was much more expensive than the unbuffered variety.
That's an awesome deal for that Supermicro board if you wanted to build your own NAS. It regularly goes for $180 plus anywhere else, those of you that have a microcenter close to you, I'm jealous.
Nope, unbuffered costs way more than registered.
I'm realizing that this Supermicro board wouldn't benefit me much at all from what I already run. I have a E3-1230 Xeon with a standard Intel DZ77-55k motherboard running my ESXi server. If I make a big purchase, I'm sure as hell going for socket 2011. It just does not make sense to spend all that money on Unbuffered to continue running on an older 115x socket.
Basically what I was trying to imply
I've done enough research into the cost of hardware. I'll just wait until DDR4 makes an impact on DDR3 prices. No need to throw more money into hardware now since more importantly, I need to keep studying up on virtualization.
While ECC is nice to have for a home setup, I think I can get by without it, however I understand the risks.
The motherboard power connector is 14pin, therefore you will need an adapter to convert 24pin to 14pin. Cost about $5 on eBay.
