microATX fit in regular ATX cases?
jdgrotte
Does that work? Does a microATX mobo fit in a regular ol' ATX mid-tower case? I mean, I know it'll obviously fit, but do the holes line up? I know there's load of extra holes on the tray, so that's what they must be used for right?
Reason I ask is that I bought/received that freebie (w/rebate) Soyo mobo from Newegg. Figure I might drop it into my old full tower for now until I decide on which new case to buy (old machine is 'vintage 1998' C300 o/c to 504!, 'bout time for an upgrade eh?).
Most cases can handle that with no issue. Double check that you have mounting holes for the smaller board, but it’s rare a case doesn’t have both mountings available.
Cool, thankx for the info.
Worst comes to worse, I suppose I could always break out the drill
I've done that, I had a PC Shits MOBO with a Athlon 950 running in a old Compaq case that originally held a 486/66.
it will work just fine, I had to use a matx in my chieftec black lightning mod due to false bottom. If you look at a mobo tray you will see that it has holes for almost any type of mobo (unless it is a dell :rolleyes: )
JEEVES
