Micro SD card Video on TV
Hulk
I recently bought a drone and when I go visit my parent's house I'd like to show them the footage I just took of their house/property on their big TV.
What's the easiest way to do this? We don't have a laptop to hook up to the TV.
Might the TV have a USB port? Some had USB ports to plug in mass storage devices. In that case you'd need a USB microSD card reader. If not, phone or laptop.
Yes, it has a USB port, so any USB card reader/mass storage device would work? What's a good cheap one?
It needs to support mass storage devices and the codec the drone used. I would start with a cheap reader since even USB 2.0 ones should work. I don't have a personal recommendation though.
