Micro ATX
mikegoes101
I'm looking for a case that would fit into the microATX category that would be light and easy to transport to lans. At the same time I have 3 active harddrives and might add a fourth. What are some of my options?
Can you be more specific as to what you're looking for? Are you looking for a mini tower? A cube? A slim form factor?
It's probably going to be tricky to find a small case that'll take four hard drives...
Well actually I went ahead and bought a standard ATX so I could have USB 3.0 and Sata 6. Now I need a case that either has a handle on it or some sort of backpack type hookup.
DIY handle?
You're going to have a tough time finding a LAN friendly mATX case that can house 3+ HD's; most of them can do 2, but not 3.
Lian Li PC-A05B
Will hold 3 drives stock, can get a 4th in the second 5.25 bay.
http://www.newegg.com/Product/NewProduct.aspx?Item=N82E16811112218
11-112-130-S09
http://www.frozencpu.com/products/2777/han-07/GearGrip_LT_Harness.html?tl=g31c187&id=cofNrVAk
Smallest case with ATX ability I know of.
