Micro ATX with Coaxial digital audio? Does it exist?
Bigbacon
I'm trying to upgrade my media PC and I can't seem to find a micro atx board that has a digital coax audio output on the board.
I searched newegg and there is nothing. I don't have an open optical
can be intel or amd, just needs to have coax audio, be mAtx, and have a single pciE slot for a video card.
AM3 only...doesn't specify AM3+ but either way, slim pickings on CPUs
My mATX has the pins for digital output on the board, just had to add the coax header.
how do you know if the motherboards have it? also many new boaeds have a 9 pin header and all the adapters i see are less
Well, i only know one that has a coax audio out, my P55 SLI Micro. It is at the right of the PS-2 connector. An old socket, but it can still rumble enough for a more-than-decent HTPC, considering most i7's are under $70 nowadays and DDR3 is dirt cheap.
Plus, nowadays an HTPC must have a good GPU for true decoding (i use madVR with NNEDI3 on my GTX 780) Even with a good 1080p video, even my i3-550 can cope with the load (the Xeon is overkill, but overkill is good).
I was thinking of buying the co-axial adaptor but where would I connect it to the board?
I have a msi titanium z170
Thanks Seithennin but I`m a bit of a purist lol and loathe converters. I`ll stick to my usb for my nuforce dac headphone amp but am limited to 24/96 kHz.
I have some van den hul graphite co-axial digital cable which I would love to use. Might have to get the Asus essence II STX soundcard which has co-axial.
