Micro ATX Suggestions?
v0rtic3s
Looking for suggestions for a socket 775 (I have an E8600 3.33 laying around) board for a micro build I want to do that can also handle gaming.
Need a solid micro 775 board, but seems hard to find anything truly reliable.
Have a Sugo SG03-F case sitting around, so figured I'd do a fun micro build and use the E8600 with a GTX 280 and Kuhler 920.
Suggestions for a solid board?
For mATX+LGA775, I'd recommend the board I have in my sig (ASUS P5G41-M LX2/GB). It can swallow any LGA775 CPU Intel has made from Conroe to Lynnfield, it includes onboard gigabit Ethernet (Realtek RTL8111E) and the single PCIe x16 slot iis a full Generation 2.0-compliant slot (thanks to the Intel G41 chipset, it can also handle ordinary use if you decide not to game).
I have mine in a full-sized ATX case.
Why mine is not for sale, despite an upcoming upgrade - I'll either hang onto it (for use as a guest PC or possible *Hackintosh-only* box; it currently triples 7 x64/Snow Leopard, and Lion) or pass it down.
A GTX280 is a fairly long card (10.5", 267 mm). Will it fit in a SG03-F? (The total case depth is 312 mm, according to Silverstone.)
