Micro ATX mobo recommendation
beanman101283
I was wondering if anyone could recommend me a good MATX board for use in a small form factor case. I'm building this for a friend of mine, it'll be used for homework, surfing the web, and light gaming. It won't be overclocked, it just has to be stable. I usually lean towards AMD but i wouldn't be against an Intel board just to get more familiar with them if it's at a good price.
I am a huge fan of Intel branded boards for what you are describing. Absolutely no overclocking (disregaurding the 4% boost you can get on some) but they are beyond rock stable. I would even say that a good Intel board, paired with a CeleronD 336 or up would make a great combination for that.
Ok, it sounds like i'll go with an Intel board then. That D945GTP looks like it has a good set of features (probably too much for his needs, but oh well) and if they're as stable as you guys have said then that'll be perfect. I think the Pentium D 820 is too far outside his price range but i'll take a look at some of the lower end P4's or maybe even the Celerons. I'm still debating on whether to stick with the integrated graphics or get a low end video card like a 6600 vanilla or maybe even a PCI Express 5900. We'll see. I appreciate the help, thanks guys.
