Micro-ATX case for a small server
  • Thread starter Deleted member 305099
  • Start date
D
Guest
I have just ordered some SSDs to replace those goddamn SAS spinners I have in our home server, and have since started thinking about shrinking the case down.
Currently the server resides in Fractal Node 804, but with four U.2 SSDs I don't need that huge drive compartment, and could very likely do with something smaller.
All I need is a case that's very well protected against dust (the Node is not the best in this regard), can take a full size PSU, and has like 3 expansion card slots.
Basically anything cube-like with horizontally oriented motherboard with the above mentioned things, and overall size smaller than the Node 804. It should have at least somewhat decent build quality.
What's out there?
Assuming you are sticking with m-ATX since you are running the Node 804. Take a look at Jonsbo. They don't have the horizontal mobo orientation, but they do have the full size PSU and 3 expansion slots you want. Here's a Link to their mATX offerings.
