Mice don't work on my computer
Zorn
The title might be a bit off, since the original mouse Ive had since I first installed Vista works, but any time I try to plug in a mouse of any sort, the following comes up:
"Windows found driver software for your device but encountered an error when attempting to install it: USB Browser Mouse
An error occurred during the installation of the device:
The driver installation file for this device is missing a necessary entry. This may be because the INF file was written for Windows 95 or later. Contact your hardware vendor."
Moving the mouse around does not cause the cursor to move around on the screen, and the mouse just in general does not work. The mouse lights up though, so it is definitely getting power. I have tried switching from my MX Revolution to a Creative Fatal1ty Laser mouse, and the Razer DeathAdder mouse, and both mice give the exact same error.
Interestingly, my media center PC, a totally seperate system, on which I had only used the VX Revolution, does the same exact thing. I got a new remote from Gyration which also serves as a mouse, and the mouse portion does not work at all, giving that identical error.
Does anyone have any clue why that error is happening (on two seperate systems no less) and how to get rid of it?
Can you remove the drivers via Device Manager?
If so, reboot, then direct the installer directly to the driver source (unzip/rar to a folder). That way you avoid Vista installing a a funk-tastic driver to support that.
Good luck!
Good luck!
The problem is that when plugged in, new mice are detected as "Unknown device" in the device manager. Trying to manually install the proper driver leads to the same window being shown as above.
Also, going to "Have Disk" or "Locate the driver manually", and pointing to the folder in which the Vista driver is contained for the mouse just leads it to tell me "No proper driver was found in that location for your device" or something similar.
Eanble USB mouse support in BIOS. Some motherboards have a setting for that.
