methods for cleaning out older WC equipment?
ChRoNo16
i got new tubing, and new XSPC coolant for a build im doing. the old coolant was some nasty thermaltake glycol crap. how do i best clean out and prep the pump and everything for new coolant?
The colors will be drastically different sdo I dont want any green left over to mess up my new stuff.
Thanks!
ChRoNo16
its the block from a Zalman Reserator 1 system Kyle, do those come apart?
ChRoNo16
FrgMstr ill check it out this week. when I put it back together will i need some kind of thread tape or sealant?
case should be here tomorrow so friday night ill do the dry fit of all components, lines layout, and get ready for the leak test run
FrgMstr
Just Plain Mean
Staff member
All blocks I have seen in the last decade all have reusable O-rings, so a very easy process. Still some block teardown videos on YouTube that I did. Here is one and most are fairly standard in design.
