Crazystick said:i ordered their 18 inch bending brake.. im not definitely 100% impressed by it. but what can you say for 30 bucks.
winston911 said:Try a good solid door with strong hinges, it works suprisingly well.
Qtip42 said:edit2: the bend isn't as nice in the center as it is towards the ends of the bending brake if you have a cheapy bending brake.
Dang.... glad to learn this as I'm needing a 30" brake to do what I want to do....JesDer said:The 30" brake has an issue with this. The gap in the center can get up to 1/16th an inch or more.. It was expected, but oh well.
Hmm- so just run another L-beam down the length? It shouldn't be too hard to drill holes to bolt a reinforcement in but I'm wondering if welding might be a better solution.JesDer said:Actually I have been thinking about picking up some steel to try and lessen the problem. Those brakes are basicly 2 lengths of L shaped steel. Adding in some extra support should help at least a little.
lamarth said:Hmm- so just run another L-beam down the length? It shouldn't be too hard to drill holes to bolt a reinforcement in but I'm wondering if welding might be a better solution.
Hmm... so this was with steel you tried it out with? I'm going to be using aluminum, so maybe in its 'stock' form the brake won't have as much trouble with aluminum. If you have any scrap aluminum around I'd be interested in hearing how it handles that.JesDer said:I really have not used it much yet. Just did some tests with scrap steel I had laying around.
mj007 said:Would this bending brake work only to make 90 degree bends? I want to curve some aluminum to make my next case's edges rounded like a Lian Li V1000's front and didn't know what tool to pick up to accomplish this.
Thanks for any suggestions... sorry if this is a bit off topic
Crazystick said:for the love of power tool gods.. where do you buy industrial hammers..
maybe even something like a air hammer that works off a compressor
