Metal enclosure for mod
the-one1
I have searched and can not find a box that fits my needs.
What I'm looking for is a metal, or plastic( if I can't find the metal one) box. Less than 4" high, less than 19" wide but more than 12" wide, and 10" deep or more
In Other words, something about the size of a 1U-3U server case.
Its for a router I'm putting together to make it look like a router and less like a PC.
My last resort is to go with Plywood, but would love it to be metal.
thnx
Not sure where you could find one of those, but it seems to me that an old vcr or dvd player case would work well. You'd just have to re-do the front panel into what you need it to be. :)
