messed with nvidia adavanced timing....bad choice
well i was messing around with advance timeing and i saw an interlace option,well i wanted to see what my monitor looked like with interlace mode....needless to say its shakey and hurt my eyes....well now whenever i put it at 1600x1200 @72hz+ or a higher resolution its interlaced....even worse that the video it outputs is stretched so bad on every resolution that the monitor settings cant correct it(example if i thin the screen it cuts off way before you can ever see the start button)can someone please help me,i tried driver cleaner and reinstalling drivers but that fixed the resolutions under 1600x1200...until i restarted the computer now its strected on all setting again.....HELP
Well whenever I uber f* something, I format. That's all I can suggest as I've no idea what "interlacing" is.
:( i thought of formatting but i really dont have anything to back up all my stuff on to, besides ATM im to lazy to formatt....unless its a last resort everytime i restart i have to set the settings in advance timing to what i copy down off my other nvidia PC at the same resolution
you should probably post this in the Nvidia forum, probably get more help there. Also, if you can...try and do a system restore. After you remove your drivers and reinstall them.
go into safe mode, uninstall drivers run driver cleaner, reboot, re-install drivers... enjoy
this should reset all options to default
That's probably the best thing to do first. Re-formatting and re-installing should be the LAST thing you do, unless there's next to nothing installed and not a lot of files you need to back up.
Some older monitors with low refresh rates could only do higher resolutions with interlacing. I have an old NEC monitor that I was using while waiting for my new LCD. It would only run 800 x 600 non-interlaced. The manual said it would do 1024 x 768 interlaced. I was tempted to try those advanced timing settings on my 7800GT. After I saw your post I decided against it. :eek: New LCD monitor arrived today so all is well.
My 7800GT is the first GeForce card I've owned so I'm not real familiar with all the ins and outs of the driver software. I'm surprised there's not a simple way of restoring the defaults.
this is what i did exactly the first time.......i think system restore might work thanks :D
you are my god,everythings perfect again,and i still have all the files i downloaded earlier today. i forgot about system restore when it stopped working on my other computer. i have my non interlace 1600x1200+ resolutions again!and everything fits on my monitor
omgwtfthankmicrosoft? :D
