memtest86
option141
anybody here use it?
if you're running at all stock speeds and voltage, should your ram get 3000+ mistakes on one of the tests run by this app?
edit for reason i posted in OC forum: because if my ram isnt supposed to be having 3000+ errors on one test, then that is affecting my OC, right?
if you're running stock speeds, and stock voltages, then your memory should have no errors running memtest for 30+ hours. If it does have errors, then you're either undervolting (try 2.6 if you're using 2.5), or you have one or more bad sticks or memory.
...and yes. Errors in Memtest=not a stable overclock.
