Memtest86 Test 6 Errors
SlvrDragon50
I am getting errors on Memtest86. Specifically, 66 errors on test 6.
I only decided to run Memtest86 because my computer isn't waking from sleep (turns on, screens dead). It is a brand new build:
MSI Z170-G45 Mobo
i7-6600k stock
2x8gb G.Skill Ripjaws V Ram (I had one kit, and one stick did not work with my mobo; new kit, both sticks seem to work)
EVGA NEX 650G1 PSU
7950 GPU
I have XMP enabled.
I have absolutely no clue what a test 6 error means or how to fix it... any suggestions?
I would fire off a ? to GSkill myself. Not sure what to say other than maybe bumping up your ram voltage a bit in case it's not up to spec or drooping. Could also check for new bios on MSI site.
Hmm. My voltage is already at 1.36V. Isn't that the upper limit of DDR4? Maybe I should just drop the clock speed to like 2600? It's just disappointing if the stick is marketed as 3000.
I do belie I have the latest BIOS though. I will ask G.skill too.
