Memtest will not even start
mbrockma
Thats about it. Any idea why?
Vista Ultimate 64 is installed. But when booting from a ubuntu disk and selected "memory test" the screen clears and the only thing left is the white bar cursor in the top left corner. It just constantly blinks, nothing ever happens. I have tried other disks, and memtest will never even start. I used the same disc with my laptop and it works fine.
It's a Gigabyte GA-P35C-DS3R motherboard, e6750, 4gb OCZ PC-6400 (2x2gb, tried it with both sticks, then each separately, same result), XFX 8600GS.
Vista has been running well, only problem was from an eSATA external HD (switched to USB and the crashing stopped). I have overclocked it to 3.6 (Orthos stable for 12+ hours). It was not overclocked the last time I tried to run memtest. The only other problem I noticed is that ubuntu freezes while the live CD is loading, after selecting start the status bar begins to go for a few minutes, then freezes at the same point every time.
are you running in AHCI with a sata cd/dvd drive ?
i had the same issue when the sata was set to ahci mode in the bios i couldn't load memtest.
