Specifications first:
P4 3.0E 478 pin, stock cooler (no overclocking)
corsair value 2 x 512 (also tried Ballistix 2 x 1GB this weekend)2.5,3,3,6 (2.62V. I think)
XP Home SP2
Enermax EG425P-VE SFMA
Abit SG-72
eVGA 6800GT with VF700 (no OCing; lite artifacts in UT2004 @ 1280x960)
I will make this quick. I upgraded to 2 one gigabyte sticks this weekend (PC4000 Ballistix above; turned off PS and used wrist strap), ran memtest86 and came up with errors. Ran on each stick individually and still came up with errors. Replaced with previous (Corsair Value) RAM, ran prime95 blend and halted after ten seconds, large FTT failed after ten seconds, small FTT failed after 2 hours. Ran memtest86 on Value RAM for nine hours and hit sixteen errors (test 1 & 7) after twenty six passes. Any ideas?
More information (2 months ago). Troubleshooting lock-ups (gaming) and corrupted data led me to a defective HD two months ago. During the trouble shooting, I ran memtest86 on the Value RAM for ten hours with no errors and prime95 blend for eight hours. What went bad in two months? Could the CPU be going bad and cause these issues? I live in Florida and do not hit the AC until I get home from work; idle is 46, load CPU temp is 60.
Voltages from MBM 5 (forgot my DMM at work):
Core 0: 1.34V
Core 1: 3.42V
3.3: 3.47V
5.00: 5.18V
12: 12.35V
These seem a little high, but then again most people complain about dipping voltages.
This build is eight months old from a local vendor (long story) and has four months left on warranty (vid. card, RAM & PS are not covered as I installed those the day I took possesion).
Any insight would be greatly appreciated.
XP Home SP2
Abit SG-72
Core 0: 1.34V
Core 1: 3.42V
3.3: 3.47V
5.00: 5.18V
12: 12.35V
