Hello, i am very confused and hopefully someone can shed some light on my situation...
I have four matching sticks of Geil PC3200 RAM. A while back, i thought that only two were good and two were bad b/c i was having some issues with them. So through a non-standardized test (windows would only go through the installation process with certain sticks), i weeded out the bad ones and kept the good ones - but i held onto the bad ones.
Well - for grins one time, while i had the old P4 machine open for another upgrade, i decided to swap the RAM sticks out and run MemTest - and they passed with no problems! So i popped them in with the other two sticks and they passed MemTest together.
Well, a couple of weeks later, the machine started doing weird things, so i re-ran memtest, and i began getting a huge volume of errors in test #8 - and lost confidence in my RAM again. It was rather consistent.
Today, i finally decided to spend some time working on the machine (it hasn't been running since the last time i ran memtest), and i took out every stick but one in order to try to determine which ones were the bad ones. The first passed MemTest perfectly. So i tried another stick in a different slot. It passed. I finally tried all four sticks, each in a different slot, and they all passed! So each stick was good, and each slot was good.
Starting to feel good about having tested them all just fine, i put them all back in the machine again and re-ran MemTest. Once again, on test #8, it came up with 48,128 errors.
Am i missing something? What do i need to do? Is it the RAM, motherboard?
Any help is appreciated!
Thanks,
Chris
Thanks,
Chris
