MemoryClockTarget Location
gwfleming
I have the 12.8 drivers installed for a MSI 6970 lightning and Windows 7 operating system. Where in the registry are "MemoryClockTarget" and "CoreClockTarget" located?
Thanks
Open Catalyst Control Center
Click Presets.
Click Add preset.
Give a name to the preset and save.
Now go to %USERPROFILE%\AppData\Local\ATI\ACE\Profiles\ (AppData folder is hidden. Select Show all files and folders in Folder Options).
In the Profiles folder, you will see the app profile you made, it will be a .xml file.
Open the .xml file with notepad, and you will see the values you are looking for.
name="CoreClockTarget"
name="MemoryClockTarget"
Save the file after setting any changes you want to make.
Now go back to Catalyst Control Center.
Select the Preset you created, and click "Apply" at the bottom of the Catalyst Control Center window to activate the profile.
Hope this helps!!
