evamodel00
- Jan 16, 2015
Hi all. I just built a new x99 based pc with the parts listed below:
I7 5930k CPU
Corsair H100i cooler
16GB 2600 DDR4 corsair
Gigabyte g1 x99 Wifi mobo
Gigabyte gtx 980 g1 GPU
1300W EVGA power supply
2x SSD 1X HDD
However, I am running into an issue here. Once I had everything together, I got all excited and wanted to set everything to the 24/7 specs I wanted to run. I set my memory to its xmp profile of 2666 mhz, and oced my processor to 4.3 GHz. I OCed the cpu first in the bios, and did stress testing. All temps were fine, was giving it around 1.28v for vcore, which I assumed was enough, and I would just get random bsod after an hour or so during maybe just web-browsing (this was after heavy gaming too). When I did the 4.3 Ghz oc in the bios the bsod came much quicker. Within a half hour or so. Using gigabytes easytune to get the same clock speed, the crash came much later, maybe within 3-5 hours.
Anyways, the bsod I always got was MEMORY_MANAGEMENT. I was going to attach my minidump text but instead i will post the debugged text in code wrappings below.
I reverted my memory back to default as well as my cpu, and have not had a crash today. I am going to enable the xmp profile tonight and let it run overnight in Microsoft's memory diagnostic program.
Does anyone have any advice on this? Is this my memory, was it somehow related to my cpu overclock, is it a driver? The only voltage I have changed manually in the bios is just testing out different vcores when doing the overclocking in the bios.
Below are 2 screenshots. One is of my bios with the voltages on the left when xmp is enabled. The second image is of my voltages via gigabytes system infomartion viewer (the second image are the voltages at crash time).
Any advice would be appreciated. Thank you,
I7 5930k CPU
2x SSD 1X HDD
Code:
Microsoft (R) Windows Debugger Version 6.3.9600.17298 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\011515-23828-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Symbol Path validation summary **************
Response Time (ms) Location
Deferred SRV*C:\Windows\symbol_cache*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*C:\Windows\symbol_cache*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 8 Kernel Version 9600 MP (12 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 9600.16452.amd64fre.winblue_gdr.131030-1505
Machine Name:
Kernel base = 0xfffff803`2380b000 PsLoadedModuleList = 0xfffff803`23acf990
Debug session time: Thu Jan 15 23:00:04.722 2015 (UTC - 5:00)
System Uptime: 0 days 2:52:21.847
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1A, {5100, fffff6e000159848, 1, 28299800000020}
Probably caused by : CI.dll ( CI!I_MinCryptGetCertificateEKUs+5d )
Followup: MachineOwner
4: kd> !analyze -v
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000005100, The subtype of the bugcheck.
Arg2: fffff6e000159848
Arg3: 0000000000000001
Arg4: 0028299800000020
Debugging Details:
BUGCHECK_STR: 0x1a_5100
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
ANALYSIS_VERSION: 6.3.9600.17298 (debuggers(dbg).141024-1500) x86fre
LAST_CONTROL_TRANSFER: from fffff8032397ea63 to fffff80323958ca0
STACK_TEXT:
ffffd000`291a42c8 fffff803`2397ea63 : 00000000`0000001a 00000000`00005100 fffff6e0`00159848 00000000`00000001 : nt!KeBugCheckEx
ffffd000`291a42d0 fffff803`23863fcb : 00000000`00000001 ffffd000`291a44a9 00000000`00000001 00000000`00000001 : nt! ?? ::FNODOBFM::`string'+0x158c3
ffffd000`291a4410 fffff803`238e9350 : 00000011`00000000 00000000`00000000 ffffd000`291a4570 fffff803`23a9b45b : nt!MiAllocatePagedPoolPages+0x1f7
ffffd000`291a4510 fffff803`23a9b440 : ffffe000`00138640 00000000`72634943 00000000`00000be0 00000000`00000001 : nt!MiAllocatePoolPages+0x28
ffffd000`291a4550 fffff800`00303ca9 : 00000000`00000004 ffffc000`2b24e1f0 00000000`00000000 00000000`00000001 : nt!ExAllocatePoolWithTag+0x430
ffffd000`291a4620 fffff800`003035d4 : 7fffffff`ffffffff 7fffffff`0000001e 00000000`00000000 00000000`00000000 : CI!I_MinCryptGetCertificateEKUs+0x5d
ffffd000`291a4690 fffff800`00301f36 : 00000011`eb1d23d5 00000000`00000002 ffffc000`2b2f3530 ffffd000`291a4b00 : CI!MinCryptVerifyCertificateWithPolicy+0x5fc
ffffd000`291a4830 fffff800`00302a4e : 00000011`eb1d130a ffffd000`291a4ad4 00000000`00000000 ffffd000`291a4bd8 : CI!MinCrypK_VerifySignedDataKModeEx+0x1da
ffffd000`291a48f0 fffff800`00302d28 : 00000000`c0000225 00000000`00000000 00000000`00000001 00000000`00000004 : CI!I_MinCryptVerifyRFC3161TimeStamp+0x63
ffffd000`291a4a80 fffff800`00302084 : 00000000`00000000 ffffc000`2b2fee90 00000000`00000000 ffffd000`291a4be8 : CI!I_MinCryptGetSigningTime+0x1d4
ffffd000`291a4b90 fffff800`002fe5e6 : 00000011`eb1d0000 00000000`00002640 00000000`00000000 ffffc000`23d64760 : CI!MinCrypK_VerifySignedDataKModeEx+0x328
ffffd000`291a4c50 fffff800`00300f43 : 00000000`00000020 ffffd000`291a4f08 ffffc000`2abf2998 00000000`00000000 : CI!I_ParseCatalog+0xd6
ffffd000`291a4d40 fffff800`002fe32e : 00000000`00000000 ffffd000`291a4f08 ffffd000`291a4f08 00000000`00000000 : CI!I_ParseCatalogAndMapHashes+0x37
ffffd000`291a4db0 fffff800`002feb49 : ffffd000`291a4f08 00000000`00000745 ffffc000`2abf2998 00000000`00002640 : CI!I_MapCatalog+0x18a
ffffd000`291a4e60 fffff800`002fe889 : 00000000`00000001 ffffd000`291a4f59 00000000`00000001 00000000`000007ff : CI!I_ReloadCatalog+0x21d
ffffd000`291a4ea0 fffff800`002fd786 : ffffe000`00000000 00000000`00000001 00000000`00000001 ffffd000`00000000 : CI!I_ReloadCatalogs+0x179
ffffd000`291a4fc0 fffff800`002fd65e : ffffd000`291a53f0 00000000`00000001 00000000`0000800c fffff800`00000000 : CI!I_FindFileOrHeaderHashInCatalogs+0x11e
ffffd000`291a5050 fffff800`002f9570 : 00000000`c0000225 ffffd000`291a51e0 00000000`00000000 00000000`00000000 : CI!MinCrypK_FindPageHashesInCatalog+0x7a
ffffd000`291a50e0 fffff800`002fa2dc : 00000000`00000000 00000000`0000800c 00000000`00000000 ffffd000`291a56e0 : CI!CipGetPageHashesForFile+0x19d
ffffd000`291a5270 fffff800`002f75cb : 00000000`0000045b ffffd000`291a56e8 00000000`00000002 00000000`000007ff : CI!CipValidatePageHash+0x4ac
ffffd000`291a5480 fffff803`23c4ccc7 : fffff800`00b3e1e8 fffff04e`edb6561b 00000000`00000000 fffff803`23bc4dbd : CI!CiValidateImageHeader+0x3fc
ffffd000`291a5610 fffff803`23c4c9ff : 00000000`00000008 00000000`00000001 00000000`00000001 00000000`00001000 : nt!SeValidateImageHeader+0x83
ffffd000`291a5690 fffff803`23ba149e : 00000000`00000212 00000000`00000214 ffffd000`00000002 ffffe000`0910f40c : nt!MiValidateSectionCreate+0x30f
ffffd000`291a5810 fffff803`23ba0a6e : ffffd000`291a5a60 00000000`00000000 00000025`00000214 ffffd000`291a5a58 : nt!MiCreateSection+0x93e
ffffd000`291a5a00 fffff803`239644b3 : ffffe000`142b7880 00000025`b505ca68 ffffd000`291a5aa8 00000000`00000000 : nt!NtCreateSection+0x1a2
ffffd000`291a5a90 00007ffe`b8b76a1a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000025`b505ca48 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`b8b76a1a
STACK_COMMAND: kb
FOLLOWUP_IP:
fffff800`00303ca9 488bf8 mov rdi,rax
SYMBOL_STACK_INDEX: 5
SYMBOL_NAME: CI!I_MinCryptGetCertificateEKUs+5d
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: CI
IMAGE_NAME: CI.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 523d51aa
IMAGE_VERSION: 6.3.9600.16408
BUCKET_ID_FUNC_OFFSET: 5d
FAILURE_BUCKET_ID: 0x1a_5100_CI!I_MinCryptGetCertificateEKUs
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x1a_5100_ci!i_mincryptgetcertificateekus
FAILURE_ID_HASH: {296c8a0d-6084-eddb-de7f-cb7d3a3c0212}
4: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
FOLLOWUP_IP:
MODULE_NAME: CI
IMAGE_NAME: CI.dll
ANALYSIS_SOURCE: KM
