Memory will not run at CMD 1t with new processor?
Diseaseboy
I recently upgraded from a Athlon 64 clawhammer 3200+ to a Athlon 64 newcastle 3400+ on a Chaintech VNF-250 motherboard. I have two Kingston 512 pc32000 modules. The modules ran fine at the default spd values and CMD of 1t with the 3200. When I upgraded to a 3400 I could no longer run the same modules at 1t. Windows wouldn't even boot. I set the command rate to 2t and everything has been fine but my memory benchmarks are low. The only thing that has changed is the processor. I also tried a different motherbaord (Gigabyte K8NS) and everything is still the same. The modules will run at 1t with them installed seperately just not in pairs. I tried increasing the memory volatge and it dind't help. Is the memory controller on the newcastle that different from the clawhammer? FYI- I am running an Antec 550 watt true control power supply ( with a stable 3.3 volt as far as I can tell) and the clawhammer was bought in Nov 2003( so it is one of the first run chips I assume). Any suggestions? Thanks.
Scott
Hey,
It's hard to say. However, with the built in memory controller, you can get good ones and bad ones. It just throws another variable into the mix.
Didja try bumping your vdimm a 'lil bit? The new proc might be taking a couple extra watts off the mobo's power and causing some flux in your vdimm.
::edit::
Like bump it up .10 to .15ish and try that.
