Memory voltage
T
trib
Guest
Is memory voltage really important to match with a motherboard? I have 2 sticks of 512MB of Kingston HyperX 3200 memory laying around which is rated at 2.6V. My motherboard is a supermicro P4SCT+ which says it requires 2.5V....I'd like to add some more memory to this board but it needs to be stable.
Any thoughts? Do you think the board will run well if I add this memory?
I'm running 2 sticks of corsair value select 3200 2.5V right now (matched)
I am sure you will be right as rain, since you will be running the ram at a slightly lower voltage. But it is such a small amount it should be fine. But there are instances....
Is your memory voltage selectable in BIOS? if so, just up it a little. I have never had problems overvolting memory, but do not, unless needed, that is...later:)
