Memory upgrade
That Corsair XMS2 kit should work with that HP system. However, there is no guarantee that it will actually work since OEM HP systems were generally designed for use with strict JEDEC-standard memory (which generally is only available directly from the manufacturer of that OEM system in question - at seriously inflated prices).
Go on newegg or similar site and bring up the memory configurator for your system then match the specs on the compatible dimms to the one you picked.
