assuming the chip can actually do 3ghz, 100%.
9x is the stock cpu multi, and 333mhz fsb with 1:1 is the highest speed you can do before overclocking the ram
333*9 = 3ghz
333*9 = 3ghz
Can I ask why it is necessary to OC your RAM to go beyond this 1:1 concept? I see all kinds of people at 3.2Ghz - 3.5Ghz on E6600s (or lower) and I am wondering what they have done to get it that high and be stable enough to even run programs or games that stress the CPU.
how much are the corsairs going to run you? perhaps, we can find you a better deal for better ram
basically, at stock 266fsb, you have for normal usage on a p965:
1:1: 266 (533)
4:5: 333 (667)
2:3: 400 (800)
now when you goto 333 (say e6600 has 9x multi, so 9x333=3000)
1:1: 333 (667)
4:5: 417 (833)
2:3: 500 (1000)
there's many different ways to run 3.2ghz, or any frequency. e6600's have selectable multipliers from 6 to 9. So taking 3.2ghz as an example, 6x533=7x457=8x400=9x356=3200.
You can apply the same three dividers for those fsbs. Usually, the best choice would be 8x400 unless you have a board that can handle 6x533 on 1066 strap (it gets complicated, so just understand that 500+ fsb is hard to get by often, so you usually wouldn't be looking at this).
So with 8x400=3200, you're running 400fsb
the lowest divider is 1:1, meaning your ram must be able to do 400 (800).
edit: I answered your question genericly, because I couldn't understand what you were trying to ask, and hoped I was able to answer it somehow.
Basically, if you're at 333fsb, and don't want to take your ram over 800mhz, then your only option is 1:1 for 667, since 4:5, the next option, will set it at 833.
Thanks, your post has been invaluable. Youve introduced some new terms to me that I wont bother you with asking about just yet.. I may PM you later on if that is OK. My ASUS Commando is supposedly pretty good for going above 500fsb.. I think. 8x400 seems good.. Now I am just wondering what sort of air cooling I will need to pull off that high of an OC. I think stock would be fast enough for what I need though.. just have the bug of modding...
I bought 2x 512 Corsair TwinX XMS8500 which I think to be very good value for money and very suitable for reaching the OC you want.
I was however advised that if I want to have a total of 2 Gig Ram I should sell these 2x 512 (1 Gig total) and buy 2x 1 Gig Ram cause a OC with 4x512 Ram is very difficult they say?
Donnow if that's true or not?
I think the right RAM is essential for a good and stable OC so don't be to Dutchy on that.
On the other hand you don't wonna get broke on it either.
ziddey -
If you had $700 in three weeks (after c2d price cuts) to purchase a motherboard, cpu, and ram, to achieve the highest mhz speed....what would you get?
