Memory Timings - Diskless Clients
EvilAlchemist
Changed some of my memory timings on my boxen and thought i would share.
Default Value: 5-5-5-12 @1.9v Corsair XMS2 TWIN2X2048-6400
Diskless 1:
Q6600 @ 3.0Ghz
4-4-4-12 @ 2.0v
From 2873.25 PPD -> 2893.40 PPD
Diskless 2:
Q6600 @ 3.0Ghz
4-4-4-12 @ 2.0v
From 2983.60 PPD -> 2927.44 PPD
Diskless 3:
Q6600 @ 2.9Ghz
4-4-4-12 @ 2.0v
From 2740.44 PPD -> 2808.49 PPD
Diskless 4:
Q6600 @ 3.0Ghz
4-4-4-12 @ 2.0v
From 2983.20 PPD -> 2913.72 PPD
Diskless 1:
Q6600 @ 3.0Ghz
4-4-4-12 @ 2.0v
From 3079.60 PPD -> 3102.64 PPD
These numbers were taken after 5 frames - will post new numbers on next WU to compare
Looks like a good way to boost PPD by a few points ....
Looking at the data from the Last WU's and the current ones....
Each boxen had about a 20-45 PPD increase just by lowing the timings a little ...
I would agree anything to speed up calculation movements should impact PPD... thus the reason I woudl suggest DDR28500 at 1066 vs 800... I would also think that if you have a 3GHZ Quad it might benefit you to run instead of 9x333FSB, to run 6x500FSB. That has been shown to increase performance on games and such by 5%... that could translate into another 100PPD... This is all theory I'm more concerned about being 100% stable right at the moment with a new box, but when I get time I will jack with the settings.
Is this using the new notfred folding iso?
I was under the impression that 2 folding clients
are used for a quad core with new iso. Should
give you a boost vs. single client....not that you need any
more boosting.
more boosting.
The new release does support 2 x SMP on the Quads.
It does give about a 10% increase in PPD.
Unlike VMWare - you still get the 4-core WU so it does not help as much.
Also, only two of my boxen have 2GB .. the rest are 1GB.
There are a few users running some tests now over on notfred's forums and I am waiting for their results.
Also waiting to see if the hang check script works while running two clients.
On a personal note, I just like having the WU complete faster on the single client but who knows......
