OK I am have a Dell Persision M6600 with the i7-2860 and 4 dimm slots
I ordered this with 4gb of memory knowing I was going to stuff 32gb in when I got the chance.
Now oddly enough from Dell they mention I can run 16gb of 1600 or 32gb of 1333
and its using the Mobile Intel® QM67 Express chipset.
To be truthful it has been way to long for me in building systems, I have been on laptops for the last 10 years+ but I would assume that the QM67 chip set won't allow for the 32gb of 1600 which seems kinda odd as it will at least handle 16gb at that speed.
So I am just kind of wondering why from a technical standpoint ( and my general curiosity )
So next up is, I am picking up the memory. I was looking at Crucial http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=4B22B2EEA5CA7304
and started poking around on new egg and was looking at :
G. Skill - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231582
Corsair Vengeance - http://www.newegg.com/Product/Product.aspx?Item=N82E16820233265
Now this is a work box, no OC'ing. I use it for video editing, etc with some Starcraft II thrown in. The thing I am seeing is a difference in the CAS timing 11-11-11 vs 10-10-10 and while I know 10 is "faster" than 11 is there really an appreciable difference ?
Given there isn't much cost difference between these kits I was just kind of wondering.
Thanks for your insight
-Robert
Up to 16GB6 DDR3 SDRAM at 1600Mhz - 4 DIMMS
Up to 32GB6 DDR3 SDRAM at 1333Mhz - 4 DIMMS
-Robert
