I didnt see a version that could be ran without burning it to disk or mounting an iso, i dont have a drive on the box at the moment.
I did find one and it did find errors. Like 50 sectors that could not be written to. I just got this ram in from newegg. There is no helping it right? Do i just need to RMA it? Ive gotten 8 random freezes and one BSOD in about 4 days
Given the 50 sectors and freezes, it's pretty obvious there's a problem. Just by getting another program is only going to further confirm your suspicions. It's not like you need to 'prove' to newegg that it's broken. Save yourself the headache and just RMA.
Do you have a USB flash drive? You can run Memtest from a flash drive. The RMA is the easy solution but I'd suggest you be sure before shipping it off.
Intel Burn Test will stress you RAM along with your CPU, but it won't tell you specifically if you run into a memory error. It'll only stress what the OS isn't already using though.
+1 for memtest on USB. On the memtest website, there's a "Pre-Compiled EXE file for USB Key (Pure DOS)" version.
