Hello
I am in the process of a new build and have a question regarding memory and CPU FSB speeds
I want to buy an intel core 2 duo and wonder if to go with one of the current models (E6600 probebly) or one of the refresh models (E6650 etc)
The main difference between the older and the refresh models are the higher FSB in the new models (from 1066MHz to 1333MHz, except in one refresh model which is still 1066MHz FSB)
First, I assume I need a MB that supports the CPU FSB of the CPU I am buying, or the CPU FSB will drop to whatever the MB supports max?
Second, just a question about 2 core 2 duo models, older and refresh: the X6800 (extreme) and the new E6800 refresh, they both have the same specs, same clock speed, cache, FSB, anyone knows what is the difference? why did they release one new model equivalent to the older extreme, or is there something different?
I am getting a 800mhz (6400) Memory, and wonder if its related to the CPU FSB speeds
Will the CPU FSB speed drop (from 1333MHz or 1066MHz, whatever I will get) from their default value to a lower value because of that memory I am getting?
Thanks for your help.
