Memory slots on motherboard giving me problems
Lyrids
A few months ago I tinkered with my RAM and as a result I'm only running half the amount of RAM I was. I have an MSI K8N Neo Platinum with two sticks of Crucial DDR400 512 MB, and three RAM slots on the motherboard. After tinkering I turned on my computer and the mobo beeped with no other response, and after some experimentation I discovered that the only RAM combination that allowed my computer to boot into Windows was one stick of RAM (either one) in the first slot. Only one other combination brought me close, and that was one stick in the first slot and another in the third. This allowed my computer to POST, and when looking in the BIOS it verified that I had a gigabyte of memory installed. However, it hangs whenever I get to the Windows loading screen (the loading bar). I don't know how to run memtest but im guessing that I'm going to be asked to. Any other suggestions?
Perhaps you need to adjust your voltage/timings in the bios? Also, can you confirm that your sticks are both good booting individually?
Memtest is pretty easy to run, just google either memtest86 or memtest86+ (both are fine), and grab the iso and burn it to a CD. Boot off the CD and memtest should run by itself. You should try it on both sticks, and each stick individually.
I did memtest, both passed no problem, both sticks will boot the computer individually. Together they're a no go.
So your computer doesn't boot even through the Bios enough to boot off of the memtest CD with 2 sticks?
Memtest begins to open when I have sticks in the first and third, but it freezes and stays locked with the GUI loaded and some words on the screen.
