memory reporting
Bontakun
Having trouble with the memory being reported. It always says 7.22gb out of 8gb is usable. Is there a setting in bios I need to mess with to fix this? Thanks.
i7 2600K
asus p8z68v-pro gen3
8gb corsair LP vengeance
win7 64bit
Looks like you're using the SB graphics, thus the lower usable memory.
Maybe, but I think that's a bit high WEI for HD 3000.
EDIT: never mind, I'm wrong, that score is definitely in HD 3000 territory. I never dreamed that WEI would show such a massive difference between HD 2000 and HD 3000:
http://forums.overclockers.co.uk/showthread.php?t=18365386
They basically throw you an entire point for the difference.
As far as I know, I thought I turned off iGPU from bios. I'm using a dedicated video card. Maybe I missed something? Is there a proper way of turning it off?
