Memory recommendations
hutch3184
Hi, I have an AMD 4000+, Gigabyte GA-K8NF-9 moby running XP. Just wondering what is the fastest and best stock 2 gig RAM stick that I could get for this system?
Well, seems that since you're asking about DDR 1 that everyone has forgotten how to hit the reply button.
Anyways, I do not believe that you can put 2gb sticks in your gigabyte. I believe that the largest single stick you could put in it is a 1gb stick. Any cheap DDR 400 would work fine, if you're not looking to overclock.
This would do just fine.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231031
