Memory Recommendation for 10700 Gaming Build
CharlesIII
What is your budget for the ram?
Do you want/need RGB?
Do you want 2x 16gb for future expansion? or is 4x 8gb ok?
Without knowing the above questions this kit is a solid bang for buck with the cyber monday deal being 3600mhz and CL16 for only $140: https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232907
Edit:
If you want RGB here's two options both at $165 depending on which color scheme you prefer.
https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232906
https://www.newegg.com/g-skill-32gb-288-pin-ddr4-sdram/p/N82E16820232861
