I've got a p4 2.8c
It's running on an ASUS P4C800-E Deluxe motherboard.
I'm going to get a better PSU. Probably an OCZ.
It's got to have modular cable design though.
I'm also about to finalize my Liquid Cooling setup. I'll have the processor cooled by a TDX with a BlackIce Extreme III and some Panaflow M1A's.
I need to upgrade my generic Samsung DDR400 RAM!
I would like to get the most out of my P4, until i switch chipsets down the road. I can o/c to just under 3.06 ghz and remain stable _without_ changing any timings or voltages. Never changed timings, not up on exactly what the ramefications of each number being changed means. Same with voltage, although that's pretty straightforward
I would like to be able to get a least 3.4 out of this chip with some performance RAM.
The processor is cooled now by an XP-120, idles around 28c, and hits loads of no more than 38c.
FYI, i'm not sure what my load temps will be post-liquid cooling... would like to give you those numbers, to help in any advice you can give, but I cant... not yet, anyhow
Soon! very very soon! Maybe someone who has a similar setup could input on temps?
To all you avid overclockers out there, what would you suggest, at a price point of approximately $200 CDN / $150-$185 USD ?
I'd like to get a minimum of 2 x 512mb.
As an aside, sort of... Can anyone give me a straight forward answer as to what is more effective, and back it up with data (link)?
1. 4 x 512mb
or
2. 2 x 1gb
Thanks a ton people.
-Mo
1. 4 x 512mb
or
2. 2 x 1gb
-Mo
