Memory question
torvalds
I just bought some new corsair memory and now im worried that its not exactly the same as my other 512mb stick. Both are corsair and both are pc3200 but im not sure that the memory timings are the same for both. The two sticks look different but both are cmx512-3200LL. If one is slightly faster than the other will i be screwing things up, or causing any kinda trouble?
You'll be fine. I run my overclocked rig with two sticks of Corsair XMS 3200LL and two sticks of Corsair XMS 3500 with tight timing 2,2,2,5 and it's stable.
Put it in.
Then run Memtest86.
If you get no errors after a couple of passes your fine.
Luck......:D
