Memory Question
SpecR1
Hi there
i have a memory question that has been confusing me for a while
i have 2gigs of ram
i can put 4x512 sticks in 3 double sided and 1 single sided and get them running @ 400mhz single channel, CAS 3
or i can put 4x512 sticks in 4 double sided and get them running @320~mhz dual channel
CAS 2.5
my question is which is faster?
i only have a day before i can either return the single sided ram or 1 of the double sided
my computer specs are
Asus A8N-E motherboard
AMD athlon 4400+ X2 dual core
Sapphire X800XL
plz help!
thanks
SpecR1 said:
Hi there
i have 2gigs of ram
CAS 2.5
Sapphire X800XL
plz help!
thanks
The official spec of Athlon 64 revE memory controllers supposedly only supports 2 double-sided modules at 400 Mhz @ 1T command rate. When going to more than that, it's supposed to require a drop to 2T command rate.
I recommend against mixing single-sided and double-sided memory. I've seen it work, but I've also seen it cause problems every once in a while. For maximum stability I recommend using identical modules with identical SPDs in a system.
When that's not possible, at least use modules with similar densities and choose either single-sided or double-sided. Mixing can be problematic sometimes.
i see, the mixing seems to be stable on my computer
but what is revE?
and im still wondering if running single channel 2gigs @ 400mhz is faster
or running dual channel 2gigs @ 333mhz is faster
thanks and sorry that im a tech newb ( i just know how to play games )^^
Have any time to run a few benchmarks? Try seeing if there are any frame rate differences in your games, and try Everest's memory benchmark in there program. If you are able to do any benchmarks I say go for it and try and figure out if you can notice any speed differences.
im not trying to sound rude and i appriciate the advice but i just want to know in theory which would run faster?
like does dual channel make up for the speed loss?
im getting mixed answers in real life so im trying the internet
thanks and sorry if i came out wrong
160mhz in dual channel will probably beat 200mhz in single.. in bandwidth definitly... the real issue is latency. if you can tighten timings up a bunch at 160mhz.. well, try it :D
so i asked 5 diff ppl in my local computer stores
3 say dual channel is faster because the dual channel makes up for the speed loss
the other 2 say single channel is faster because the dual channel doesn't make up for the speed loss
does anyone have a definite answer? is there even a definate answer?
i play alot of video games and i multi task alot, duno if that helps though
in terms of theoretcial bandwidth...
160mhz, dual channel = 5120mb/s
200mhz, single channel = 3200mb/s
your call on that one.
the latency at 160mhz is what has me worried, esp with 2T due to 4 sticks, but if you can get the other timings a lot lower, it might make up for it.
are u referring to CAS Latency ?
@400mhz it runs @ 3 CAS
and @ 333mhz it runs @ 2.5 CAS
sorry if im mistaken cause im a tech noob =P
Latency isn't a big deal on a64 systems due to the on-chip mem controller, I see virtually no difference from cas3 to cas2 on my system (maybe 50 3dmarks or something?), but then again I didn't see much difference between s754 and s939 (bandwidth), but it was bigger than the latency difference. I'd go for the dual channel setup...
no, i mean overall latency. cas is just one timing of ~10 that have a noticable effect on latency.
latency is dependant on two things:
mhz. faster mhz = less time between for each "timing", which is set by clocks ;)
timings. lower timings obviously mean less time ;)
ok so i finnaly downloaded a benchmark program
and these are the numbers that i got from the benchmark
Single Channel Dual Channel
Memory Read 2960 MB/s 4329 MB/s
Memory Write 1010 MB/s 1431 MB/s
Memory Latency 69.7 ns 73.0 ns
so the memory read/wirte is better but does that make up for the lower latency ?
yes, a 3ns (5%) difference in latency is nothing vs 50% higher read and write bandwidth....You will never notice the latency difference but the bandwidth will make a difference.
definitly.
what exact settings were you running at for both btw?
what do u mean by settings?
i just started my computer and left everything the same for both tests
i actually ran 3 of each test
as in what timings is your ram running at, cpu speed, etc... the settings :p
CPU Type DualCore AMD Athlon 64 X2, 2216 MHz (11 x 201) 4400+
Motherboard Name Asus A8N-E (3 PCI, 2 PCI-E x1, 1 PCI-E x4, 1 PCI-E x16, 4 DDR DIMM, Audio, Gigabit LAN)
Motherboard Chipset nVIDIA nForce4 Ultra, AMD Hammer
The dual channel ran @ Dual PC2500 DDR 2.5-3-3-7
The single channel @ PC3200 DDR SDRAM 3-3-3-8
all right :D
now, with both sticks in, have you tried tightening up the timings from 2.5-3-3? use memtest to check stability before booting into windows if you do though ;)
(cf)Eclipse said:
all right :D
i use 4x512 and how do i tighten up the timings? just go into the BIOS?
