Memory probs on P5B Deluxe
Mr. D.
I have an Asus P5B deluxe mobo with 4x1GB of RAM. For some reason, windows only shows 3GB of ram. I am certain that the modules themselves are ok because my system works fine with each individual module. So I am thinking there must be some compatibility issue with them. I already had the elixir modules when i bought the Kingstons. I chose the kingstons with the same specs as the elixir modules :mad:
I had to set the memory timings to actually get the system to be stable. If the timings are set to auto, even though the exact same timings are applied (5-5-5), the system gives a blue screen and reboots after a few hours. Is this a known issue or is thge board defective?
What operating system are you using? If it's a 32-bit Windows OS, it will not be capable of using all 4GB of system memory due to limitations regarding the maximum memory address space.
On my P5B Deluxe I had to increase the voltage when I went to 4 sticks of RAM, even though they were all identical sticks that ran at 1.8v before, I needed 1.9v with 4 sticks. So for the stability problem, you might try bumping the RAM voltage a little bit and run OCCT, Orthos or Memtest to check stability.
4gb is a limitation of 32-bit OS's, not a defect in the board, as Zero82z points out. 3gbs plus/minus is what we all get.
I am running winXP 32bit. and since 2^32=4294967296 i expected to be able to use all 4 gigs. But I am sure it is not an OS problem because the bios also reports 3GB. I am going to try tp up the voltage and see what happens.
in your BIOS you need to enable the memory remap setting - dont remember exactly where but then you will see all 4gb when you boot, but the OS is still going to only show 3 gb
