specialk12882
- Mar 6, 2005
I'm building a new system
AMD64 FX55
Asus A8N-SLI Premium
1gig G.Skill 1GBGH
2x eVGA 7800GTX SLI
PCP&C 510 SLI
2x WD Raptor 74gig
In the bios, the motherboard is setting the SPD timings to 2.5 - 3 - 3 - 5 2T even though using CPU-Z, the SPD settings are 2 - 2 - 2 - 5 1T. When I manually set the correct timings, Prime95 fails after 9-14 hours. This is with a vDIMM of 2.7-2.9v. Loosening the memory timings helps, but I would like to run it at the timings I purchased it for. Any ideas?
AMD64 FX55
1gig G.Skill 1GBGH
2x eVGA 7800GTX SLI
PCP&C 510 SLI
2x WD Raptor 74gig
