Memory Problems 256mb recognized out of 512mb
bivoauc
Setup Previous to upgrade
Barton 3000
MSI KT6V-LSR
Generic 266Mhz 256 DDR x 2
I ordered corsair 1 Gbyte TwinX Matched memory pair and installed them. Had issues (Windows would blue screen) Ran MemTest86 and the new modules failed every test. Put back in the previous ram listed above and now the motherboard will only recognize 256 out of the 512.
Troubleshooting performed:
Tried each module separately in each slot. (Computer would not boot)
Tried both modules at the same time in both slots(Computer boots 256mb is all that is recognized).
Tried setting the motherboard bios setting to default and booting(256mb is all that is recognized)
Any ideas on a fix?
Have you tried Memtesting the old sticks? They could be faulty. It could also be a motherboard issue, possibly the memory slots were damaged when you used the other RAM.
I have that running at the moment. Its 50% through so far with no problems.
[Edit]
Finished the test w/ 0 errors. Talked my roomate into letting me use one of his comps to test
the new memory. Windows started fine and memtest has been running for 10 minutes with no errors. Looks like its time to use the warranty on the mb.
